Hello,
Since the Howard County switchover to the new radio system (early 2020?) - the audio quality I've gotten from my scanner has been extremely choppy. I have tried moving the scanner to different areas in the county and it is always the same. I have re-programmed the frequencies several times, and also tried adjusting the sound quality adjustment - present it is low: 533, Mid: 1985, and Upp: 3342
When I hear audio, I notice it jumping quickly between frequencies, for example 860.2375 and 857.2375, and then flashing rapidly between DAT, NFM, P25, and LNK.
My scanner is a Uniden BC296D. It worked great, and audio quality before the switch and is basically unusable after. Is my scanner too old? Any other suggestions to try?
Thank you.
Thank you.
