HP-1 Audio anomaly
hydrolocked
I'm hearing a pretty bad hiss whenever the radio is going to make noise (beeps, clicks, receive signals) - so whenever the audio amp is active. I AM running through an amplified speaker, so that could be part of it... but has anyone else experienced this?
(edit)
This was NOT an issue with my 996.
OCO
Central Michigan
For what it's worth, here's what I found.... Note that if you're using a single amplified speaker (mono plug) then the 2.5 to 3.5 MM stereo-mono (RS 274-381) is fine also....
daveharpe
Los Angeles
My unit produces hiss and clicks while scanning certain trunk radio systems, even with mute selected. I am using the built-in speaker. Very annoying in a quiet room.
nosoup4u
High Bridge, NJ
I have noticed this when it scans a P25 trunk system and there is no activity.
Sent from my iPad using Tapatalk
