Would it be possible for someone to explain to me in laymans terms .. How to set up a favorites list On my Hp-1 ??
I don't know what U already tried so I hope I wont say something you already did...
On Sentinel, Click on the Star with a pen icon (Or "Edit" - "Edit Favorite List")
Then, a new window should apper.
Click on "New Facorite List".
A new window should apear.
Click on the Green Cross
This is where you choose the type of system (conventional etc...)
After that, select the new system on the left column.
You can now add a department, site, or channel depending of the type of system you created.
One thing you can do is to select a system on the Database and put it on your favorite list.
You'll see how it appears and you can start from that point...
I read contents post on Sentinel, and still can not get a fav list set up... Nor do I know how to run only that list when monitoring Hp-1.....
I don't have my HP in from of me but if I do remember:
You select Manage favorite list, then Multiple List, Then you select the different list you have (the one you will have created will appear and you will be able to select them and de-select the Full Database.)
My explanation are really not perfect but I hope this helps..
