HP extreme question
pike63
If you get the upgrade to your HP scanner and it has to be replaced under warranty can you get the upgrade switched to the replacement scanner?
pike63
Would not help in this case because Radio Shack would be replacing the scanner and not uniden. Thanks for the info but I wonder if you could send proof they replaced it to uniden and they would replace the upgrade.
