Just a question for all the HP experts. I have a new HP with the extreme upgrade. I've got a question about the signal reception of the unit. I'm listening to a P25 Simulcast system with 3 different sites. I've got all the control channels programmed into one single site favorite system. When watching the HP screen the signal meter in the top right hand corner will be full scale for a few seconds then completely go blank as if there is no received signal. About 2-3 seconds later the full scale will return lasting a few seconds. This cycle repeats itself. Upon looking at it under the system analyze feature on the HP it is very similar on the signal strength scale. The quality scale remains high as well as the activity scale. This particular system is very busy so I know there is a lot of traffic on it. I frequently do not hear the expected amount of traffic. I have all the usual agency types selected to receive. I'm geographically in the center of all 3 system tower sites. I have listened to it both on the database side and on the favorite system I built with similar results. I actually programmed all the control channels off a code plug from an active radio on the system itself. I'm just curious if this is normal for the HP? I'm guessing the loss of signal meter times is the unit just searching for another control channel? Is it better to build a system site for each tower site on the system. The HP is attached to an external NMO 800 MHz commercial antenna on the vehicle so I don't think the antenna is the issue. I have other systems that seem to work just fine. The HP has 2.0.4 firmware. I've tried downgrading the firmware with same if not worse reception quality. Any thoughts would be appreciated. Thanks!!
