Hp1 and 536 shortcut
lawman210
I have a sentinel download shortcut for my Hp1 and when I downloaded new software for the 536 I got a totally different icon. Do I need to use each one for each separate scanner model? How do I keep the favorites list separate? I may want some departments on one while not on another
Sent from my SCH-I545 using Tapatalk
fxdscon
¯\_(ツ)_/¯
They are 2 separate programs. One program is for your Home Patrol, and the other is for the x36hp scanners. Do you see the splash screen when they start running? It tells you which scanner they are for. They will maintain separate favorites lists for each scanner without you having to do anything. You can not use one for the other scanner it was not meant for, it won't even recognize the other radio.
If you want to share the lists between scanners, you can with export/import.
