HP1 Li-ion or Li-polymer batteries
Rbp1414
Can the HP1 safely operate using li-ion or li-polymer batteries? thanks.
Essexscan
North Jersey
what kind do you mean? The 14500 AA sized ones? If so, the answer is NO NO NO they are 3.7 volts each and in 4 in series will result blown fuse at the least and Likely a fried circuit board or two.
USE NI-MH 1.2 volt AA rechargables like ENELOOPS or Alkalines like Duarcells for emergency use
Rbp1414
any kind. not a battery expert, but is there a li ion/polymer battery with similar properties to the batteries that came with the HP? just want to have a bit better performance and life span.
Essexscan
North Jersey
Trust me and the rest of the guys here when we say buy a couple packs 8 or 12 or a kit from Costco or walmart with a Charger and you'll be surprised at the runtime and long life from the Sanyo Eneloops.
They work and they are worth it. Do a search for battery options or power outage options on here and see what everyone says about them. Li-Ion are powerful but they require constant watching to keep them safe.
external charge your eneloops like we do here and you will enjoy your scanner for years,
