HP2 - Discovery Mode question
ansky
NJ
I have an HP2 with the Extreme upgrade. What I'm trying to do is listen to my scanner while it's in Discovery Mode, that way I can hear any new talk groups that may not be in the database. But as far as I can tell the HP2 will only log the talk groups into a list, and you can't listen to the trunked system while it's logging. Does anyone know if this is possible? When I had a Radio Shack scanner this was called "Open Mode" and you could hear every talk group within a trunked system even if you did not have it programmed.
jonwienke
More Info Coming Soon!
VA
It's one of the system settings. You don't need the extreme upgrade to access it.
marksmith
Anne Arundel County, MD
You must be in a favorites list, and select a system. ID Search on is one option.
Do it from Sentinel.
536/436/WS1095/HP1/HP2/996T/996XT/996P2/396XT/325P2/PSR800/15X/others
ansky
NJ
Go to
Advanced
Edit System
Edit System Options
ID Search
slayer816
NE Louisiana
Go to
Advanced
Edit System
Edit System Options
ID Search
Or by hand:
Menu
Advanced Menu
Advanced Option
Edit Favorites Lists
(Select your preferred favorites list)
(Select the system you want)
Edit System Options
ID Search: On
