So I have several favorites list set up about two pages worth everything works except for three favorites list that are outside of my area.
If I use the full database I can listen to the same systems that I had put in a favorites list when I click on my favorites list it loads very fast but it doesn’t load any frequencies it sits at zero when I hit listen it gives me the option of cutting service types changing my range or changing at your service
If I use the full database I can listen to the same systems that I had put in a favorites list when I click on my favorites list it loads very fast but it doesn’t load any frequencies it sits at zero when I hit listen it gives me the option of cutting service types changing my range or changing at your less if I go to the service types every single one of them is grayed out for these particular favorites list I don’t know if it’s stuck in GPS mode or something but I haven’t made any changes nothing is avoided or locked out. I am not sure what has changed, except I took scanner out of vehicle to use in the house.
