HP2 in a News Helicopter
kayn1n32008
ØÆSØ
Sector 001
A helicopter flying at or above 100 feet AGL is going to be above the local clutter and will receive a stronger signal from the system, not a weaker signal. Despite comments to the contrary. Your radio is getting interfered with. If this were simulcast system, it would be expected to receive multiple sites with intersymbol distortion, a problem for commercial radios and especially with the HP2 given the Uniden discriminator demodulator. If it is not simulcast system, then I would suspect interference from comm systems aboard. Most likely the transponders. If this is a P25 system you are monitoring, I would be concerned with doppler from the rotor blades.
Another problem might be adjacent channel systems that become an interferer above 100 feet AGL. The frequency coordinator study probably assumed local clutter will reduce costs channel interference.
I can assure you it isn't a lack of signal.
Sent from my SM-T350 using Tapatalk
Completely agree. He is likely being desensed from being in the air.
rwier
Phoenix, AZ
" ... Radio Reference data base does not reflect simulcast ... "
https://www.radioreference.com/apps/db/?sid=7078
" ... This new Project 25 digital simulcast network, will replace the old legacy trunked system used by many public safety agencies in and around the Nashville Metro area. ... "
If this is the System referred to?
