Have to check that out.You can get mounting solutions that match the Uniden clip at RAM Mounts.
I have a Uniden clip. Checking some of the Ram mounts. Does the Uniden clip have its 2 bolt holes in the "industry standard AMPS hole pattern"?You can get mounting solutions that match the Uniden clip at RAM Mounts.
I use the Uniden mount attached to a ram ball socket. Then the assembly is mounted on a Garmin beanbag GPS mount that sits on top of my dash. Works well for me.
How does the Uniden mount attach to the ball socket? Do you have pics or part numbers.
Thanks to all for the responses.
Thanks. Think I found a Ram mounting configuration that will work better than what I am using.It does uses the industry standard hole pattern.
Here is the adapter. I got mine on eBay, but I guess it is not a Ram product. It is Akron. Here is the link with price and part #
17mm Ball to 4-Hole AMPS Adapter with Tightening Ring: Arkon.com
