hpdb.config help needed
paqux2005
Quebec Quebec
I have a uniden home patrol with extreme. my version is is 2.01 . My database version shows xx/xx/xxxx on the scanner. When I go to try an update the firmware with sentinel versio 2,02 rev 4 I get a updating HP failed. could not find D:\ home patrol\HPDB\hpdb.config
Any help is greatly appreciated
hiegtx
Dallas, TX
The current version for the Home Patrol-1 or -2 scanners is 2.03 revision 02
Link to updated Sentinel:
If Sentinel is looking at the wrong file location (such as, you do not have a "D:\ drive), the location used can be set under the Options selection of the drop-down Tools menu:
86021
Ubbe
Stockholm, Sweden
Some software programs have problems with virtual drives or networked drives.
If you can't solve it then you can get the firmware files from the HP-1 forum on groups.io and put in the firmware folder on the scanners SD card.
/Ubbe
phask
KZZV - SE Ohio
D:\ home patrol\HPDB\hpdb.config Do you have a D: drive and is that where the file actually is?
