- Joined
- Nov 4, 2016
- Messages
- 822
Hi all,
I've had a HPII for a few years now. It's always been reliable, except for newer simulcast and what not transmissions just because of the advancements in that technology. As an analog and basic P25 scanner it's been great.
I have noticed recently, however, that a couple of systems that it used to pick up better are coming in significantly weaker with a lot of annoying static. I have other units that also monitor these same two systems and I have not heard any change with their receive. There has always been some static with those two systems on all the scanners but this HPII issue is a recent development. Other systems seem to still be coming in okay (as far as I can tell, anyway).
I don't know if there is a connection but I did copy the programming onto HomePatrol sentinal recently in case I needed to restore it.
This weekend I will do some experimenting (check antenna connection, move it around a bit to see if reception improves, all the usual courses of action).
Since the unit has not been moved from it's physical location in 2+ years, is it at all a possible symptom of a failing unit, even though other systems are coming in the same as they always have? I worry about that because my other units appear unchanged and I use the recording feature daily on the HPII to monitor my town's Fire & EMS dispatches so it's recording constantly from 7:00 - 18:00 every day.
Thanks in advance.
Thanks in advance.
