Hey guys, I had some time tonight (plus it was pretty quiet) to get things added. I got pretty much everything you guys listed talkgroup, and station wise I think. Check out the feed details for more info :
HRM Fire Radio and VHF Paging Live Audio Feed
Not sure I will pick everything up, but it's worth a shot
I just checked it out and i see you do have Transit Ops that would be mine Best thing to listen to so i am just waiting to hear them is there a chance you would be able to pick them up ?
you know another thing you could try i seen it onther feeds is called live calls that should be able to pick up everything we reuested it
i will attach a link about it so you could try that as well
Broadcastify-Calls - The RadioReference Wiki.
here is the Link on how live calls work i am 100% that should be able to pick up all of the TG would you be wiling to give this a try
this is a example of live Calls for my area so i think that it work best to get all of the Talkgroups to work
it seem to be working really good for my area so im thinking it should work well for you too
Broadcastify Calls is different from regular broadcastify feeds as the calls platform captures
every single call on a conventional or trunked system, as individual call files, and makes those calls available
[1] in real time and in archives. The Broadcastify Calls platform is not intended to replace regular Broadcastify audio streams at this time, but to supplement them, and we will eventually create Broadcastify audio streams from the Broadcastify Calls platform.
Broadcastify Calls makes available to call ingest providers ALL calls they send to us, but limits public access to calls covered by our
Feed Provider Terms of Service
Broadcastify Calls Features includes:
- 30 day retention
- duplicate call handling
- Live Call Playback
- Playlists Playback
- tight integration with the RadioReference database
- call and source detailed statistics
as it says in the description it captures every single call on Trunked and Conventional system so this is 100% the way to go for Listing to the talkgroups please give it a try then we can all be happy and enjoy listing
you need to create a playlist with the Live calls then it should be good with Transit Ops fire Emo intercop ect
@west5alpha i told him to do a live calls for the Talkgroups we requested i have that in my area and it pick up every call on in my area on trunk system and coventional so we should be in Luck with the live calls
