Hsdr bad audio
ansul1001
#1 Member
Hesperia California
Hello does anyone know of a way to get rid of choppy audio on HDSDR with a rlt3892 usb stick is it just a setting or something else i am running the latest version of HDSDR
KS4JU
You should probably check a couple of things:
1. When everything is running check you CPU usage. It may be your PC is not handling the load well. Usually most PCs with dual cores will work fine. If you have a single core CPU, that could be a problem.
2. Try lowering the sample rate.
3. Try SDR# since it is a bit more efficient with the RTL2832u dongles.
boatbod
Talbot Co, MD
Decode is also going to be dependent on having sufficiently good signal to work with. If the signal to noise ratio is poor, the decoded audio will be necessarily be choppy.
ansul1001
#1 Member
Hesperia California
my question is how do you control the size of the bar on the spectrum display like on sdr i am only receiving part of the freq like the filter is cutting it out
Ansul you want me to remote into your system and setup hdsdr? I have experience in both the rtl and hdsdr
Let me know
Mike
