HT-1250 220mhz Power Issue
AESFTW
I have a HT-1250 that i use on the 220 band. When the power knob is turned off and battery is placed on the unit the unit emits the power up tone but shuts off. Note the knob is off at this point. When the knob is turned on the unit doesn't power up. When the knob is turned on and the battery is placed on it then it powers up and works as normal. When the unit is then turned off the screen shuts off but the back-light remains on. At this point to power the unit back up you must remove battery, turn knob on and place battery back in. This issue just started happening and prior to that the unit worked with no issues. Its not a battery issue as this problem exists with all batteries I have tested.
N1GTL
CT
Even though the HT1250 has a positive click type switch, it still functions as a soft button power button (like a computer) rather than like a household light switch, where it truly stops all current. Without looking at the radio, I'd say you need to replace the volume/switch.
