Ht-1250 programming question
btromp
Eastlake, OH
You'll need to look in device manager to see what com port is assigned, then choose that com port in the CPS.
Baker845
anywhere
trying usb to serial adapter from the rib box, it doesn't read the radio. the com port is correct. not sure what i need to change ??
N4KVE
PALM BEACH, FLORIDA
Many times the computer does not get along with the chip used in the adaptor. A $50 XP laptop with a real serial port is the solution.
toolman60
sounds like a driver problem. what version driver you installing? a lot of people having trouble with the usb prolific clone chips floating around in cables out there and use 3.2.0.0 drivers with some sucess
toolman60
Baker845,
I agree 100%. But I was trying to give him some options to try while waiting on FedEx etc to show up with the laptop w/ good ole serial port
clbsquared
Isle of Wight County
Not to sound like a smart a@#, but, is your RIB powered on? Good battery / power supply? Also for what it's worth, there are a few ribless USB cables with FTDI chipsets that work quite well with Windows 7 and WARIS series radios.
Sent from my HTC One A9 using Tapatalk
Baker845
anywhere
the rib box is on, the person i traded the radio from was using FTDI cable, the one i have is not.
KI7OGT
This might sound funny... But try licking the programming port on the radio. I've had radios read after doing that, when they would not read before.
