ht 1250 yellow case
svfd17
Spring Valley NY
Wirelessly posted (BlackBerry8530/5.0.0.654 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/389)
Hi, does anyone know how hard it would be to put the yellow case that I see in refurb kits on the radio? Do you have to recase it or does it just slip over it?
bezking
On the Road
It's a recase. You remove the black front housing and replace it with the yellow.
svfd17
Spring Valley NY
Thanks for the quick response, just got a uhf ls+ and I love it, also got the audio adapter speaker mic and leather holster.
MTS2000des
5B2_BEE00 Czar
you have to be REAL CAREFUL when removing the old front cover UC flex. I damaged mine and had to replace the entire flex assembly. Since the radio has other issues, I buttoned it up and sent it to the depot for flat rate.
Ended up with a completely new radio:lol:, new uni-board, rear chassis, seals, front cover and display board and all.
If you aren't skilled at radio repair, I'd recommend you take it to a shop to do it. It is not a simple plastic swap, you have to transfer the display board, speaker and mic/UC flex assembly over too.
svfd17
Spring Valley NY
Thanks for the heads up, I think I'll get it done professionally.
IAmSixNine
Dallas, TX
Does your case have the speaker flex assembly already inside or is it just case with no electronics?
If its just the case and no electronics its a good idea to let someone with experience do those.
if its a complete unit with all cables/ribbons then you might be able to do it your self..
