HT-750 Programming
bigdoggg
North Carolina
What CPS is needed to program a HT-750? Have a few that need to be reprogrammed.
Is it freeware available on motorola's website like other CPS programs?
Thanks.
FFPM571
Chicago area
There is no such thing as freeware for Motorola CPS. If you have the subscription to the CPS for that radio you can get the latest versions. But it is not free
SteveC0625
Northville, NY (Fulton County)
Thanks.
You should have read the sticky at the top of this sub-forum: http://forums.radioreference.com/motorola-forum/74748-you-looking-free-programming-software.html
  • The CPS for the HT750 is $265 and only available from Motorola.
  • The cable to program the radio can cost anywhere from $30 to $150 depending on what you buy.
  • The CPS is not user friendly and takes a great deal of learning to be used properly.
Probably cheaper to take it to the radio shop then.
Had you used the search function here, you would have found that we have provided the same information and made the same recommendation to dozens of other people.
Edit to add: The CPS is HVN9025 for the Professional Series.
