HT Programming Software Question
W3LDR
So I am just got a Radioddity gc5 Suppose to be same as Baofeng UV17 and they use CPS software only thing I old ever used CHIRP for UV5s which is not compatible with this radio. The issue is the entries are not the same. I am sure they are but named different. I wanted to see if someone can line me out and help me get n track because CHIRP has a lot mor fields than CPS and when i tried to enter what i thought was correct i could not hit and open a local repearter however could with the UV5 old radio. Any help is appreciated if someone can explain where i need to plug in the data from the old radio. Here is a spread sheet with a know active repeater and a copy of the header on CPS software.... I did also find some sub menus in CPS so perhaps someof the settings need changed there as well
Downloaded from CHIRP Know active repeater
CPS Options Below
