HT1000 issue
Rconk312
Sayreville NJ
I have an HT100 I am trying to program. I am using a Dell Inspirion 600 M with Windows XP. I have the RSS software installed and have been running it in the command prompt from windows. I can open the program however I cannot read the radio. How can I fix that?
bezking
On the Road
You need to run the RSS in true DOS, not a DOS window. You'll also want to make sure you are using a real serial port, not a USB-Serial converter, if possible.
To boot your PC into True DOS you can use a DOS boot disk.
bezking
On the Road
You need to use the link I gave you. Download the XP boot disk and burn it to CD. Then you need to boot your PC from the CD. How you will do this will vary based on the computer you are using.
