HT1000 Programing Help
NJ5201
What are the PC & Software Requirements for HT1000,HT1250,MT2000 with a rib-less cable?
DPapay
Morris County, N.J.
HT1000 - RVN4098 - Software for the HT/JT1000/Visar - DOS Based, need win95/98 with pure DOS recommended.
MT2000 - RVN4097 - Software for the MT2000/MTX8000/MTX9000/MTS2000 - DOS Based, same as above
HT1250 - HVN9025 - Software for the HT750/1250/1550 CDM750/1250/1550 EX500/600 - Windows based, 95/98/2000/XP, not sure about Vista.
Don't know any of the ribless cables.
terminus
New Mexico
I've bought a few of the ribless cables from kawamall on ebay, they have worked fine on both HT1000 and MT2000.... as you will have seen the older rss requires very old systems, I haven't tried anything faster than 166mhz so far. You can download MSDOS 7.10 (it's in the public domain now) from several places on the net, and I've found that a good (OLD) laptop is the best platform. I obtain some comfort level in knowing I have a built-in battery independent of UPS or commercial power when programming the radios.
I wrote something about programming ht1000s (although I've been told there is an rss manual out there in pdf, but I haven't been able to locate it) here http://terminus.attitude.net/motorola-radios hope it helps
terminus
New Mexico
ducommff
You don't have to use a computer that is that slow. I am using a Toshiba Laptop with a Pentium 3 processor in it and running window 98se. I can program a ht1000 just fine on it. I also use the laptop to program my spectra mobiles and my mts2000 portables. I have no problem programming a MSF5000 i have.
terminus
New Mexico
What CPU speed please?
w8jjr
Lincoln MI
I picked up a 386 laptop off of ebay for $0.99 and 12.00 shipping. I use it for the rss.
I've tried P3 and they would not work. Really depends on speed of the cpu.
shaft
Wentzville, Mo
I've been using a P4 2.13ghz laptop that I boot into FreeDOS to program my HT1000 with no issues.
terminus
New Mexico
Hmm... Ok, well maybe this weekend I'll get some brass and give a much faster machine a go. I can't afford to brick any of my radios but it sure would be nice to stop maintaining these old machines. I have to admit though, it was fun restoring a few of the old laptops :) I ended up installing a dual boot msdos and debian linux on some of the 166mhz machines. For the thrill of seeing a modern unix kernel run on a 166mhz POS of course!
ducommff
The laptop is running at 850 MHz. I have noticed that people with Toshiba, IBM and Gateway laptops seem to work pretty good for Motorola radio programming.
CommJunkie
FN20jf
I have an HT1000 question that I didn't see a need for starting a new thread...
Is the HT1000 programmable with the same RSS and cable as the MT2000?
Thanks.
terminus
New Mexico
The same cable will work, but not the same RSS.
The RSS for HT1000 is called "ht1000" and the RSS for MT2000 is "mtsx"
I am starting to put together a resource for these (2) models here: Terminus: Motorola Radios it has some stuff there already.
KJ4CYM
I have run the HT1000 RSS on two PIII 800MHz with no issues. Same with the latest Saber, Maxtrac, Maratrac, and MTSX RSS's. I did use real dos mode, (either a 98SE bootdisk, or the reboot to DOS mode from 98SEoption.)
w8jjr
Lincoln MI
see attached it may help you
  • motorola_rss_help.pdf
jewie27
Los Angeles, CA
Rss software
Where can I get a good deal on the programing software? I saw it online for over $400...the radio was $200, that's crazy.
KG4INW
Midlothian, VA
The absolute only legal way is to purchase it directly from Motorola and no where else (and pay whatever they charge), unfortunately.
2wayfreq
NM Kirk City
I recently had trouble writing an MT2000 with a P-II CPU, I would get "Radio Ack failed" or something like that. It was just too fast for the MT's controller. So, I pulled out the restored 286-16 4MB RAM with DOS 6.22 on it. It took a while for it to validate the codeplug and start the write process. But it worked! SO, SAVE those old machines!
