HT1000 Software Question
MotoMoMo
Ocean County, NJ
I have the software on CD but the problem is the windows 95 era computer cant read the cd because it is of a newer format type. I keep getting a cd103 error. I know the cd is good and such. Any ideas would be great. Thank you
cmdrwill
So Cali
The HT1000 RSS will NOT run in windows, not even a DOS Window.
Got to boot you computer directly to the command prompt so it does NOT go into Windows.
Copy the RSS onto a floppy disk, remove the Read Only attribute form the files on the disk.
rakerland
San Carlos, CA
Copy and paste to a floppy disk. I had to get an external A drive for my newer laptop to transfer to floppy disk to boot into DOS on my 95 laptop
MotoMoMo
Ocean County, NJ
Looks like thats what I'm gonna have to do, unless someone locally can help me out? What kind of 3.5 drive did you get? Connected with usb?
rakerland
San Carlos, CA
It was an external A: drive with a USB connection. Nothing special, I paid about 20$ for the thing and a pack of Floppy Disks. It should just be able to Copy and Paste if all of the files are correct. I did have a propblem with extended memory on one of my RSS programs, you just click properties on the .Exe file and up the memory.
Check your PM I am sending you a message
cmdrwill
So Cali
From the floppy you can copy the RSS files to the hard drive in a directory called: C:\MRSS\HT100.
And run from that directory.
b7spectra
EMS Dispatcher
Cobb County, GA
Dang! I'm surprised the SAPS haven't jumped on this one!
Are you still in need of a CD drive? What type laptop is it? I've got several laying around in the basement.
