HT1000 w/super low audio on receive problem
spdfile1
/\/\ Junkie
Port St. Lucie,FL
I have an HT1000 (UHF) in which I swapped out the back plate that holds the battery because one of the clips on the bottom was broken. The swap out was successful and the radio powers up fine and transmits like it's supposed to. The problem is when I test it's receive capability I hear the radio key up but the audio is super low to the point where you can't make out any voice. No static just a sound that tells you it's receiving the signal but no audio. I have not hooked it up to RSS yet as I'm just about finished installing it on my Panasonic Toughbook CF-27 but anyone have any ideas as to the issue? Thanks!!!
Scott S. (N4SYR)
Double check the seating of the board, and flex for speaker, it may have dirty connection or not fully slid into the connector all the way.
I am guessing you don't have a spare around to test the speaker so I'd double check that since it worked fine prior and be sure debris is clear from the speaker housing inside.
spdfile1
/\/\ Junkie
Port St. Lucie,FL
I actually did swap out the front cover (with speaker) in hopes that it was only the speaker but it didn’t change anything so it’s something more unfortunately. I’ve got a bunch of parts luckily.
So it worked fine prior to the housing bring removed? Hmmm.
When was last time tuning was done, and is the frequencit's narrow properly or wide as system you use are?
Have you inspected the board and checked any components for failure?
spdfile1
/\/\ Junkie
Port St. Lucie,FL
I'm actually not sure if it was doing it before I swapped out the back plate. I was just gonna use it for parts but once I saw someone on ebay selling Jedi Series radio parts for $20 I jumped on it. When it came it had everything I needed to swap out the back. It's got all ham radio 70cm stuff programmed on it. I have to hook it up to RSS and see what the settings are. My friend said possibly the volume or gain needs to be bumped up. Once I get it on RSS I'll see if there are changes I can make otherwise I'll give to another ham radio friend who knows more about fixing radios to look at it.
