HT1000 won't key up repeater
kc2vvj
Washingtonville
I programmed a few repeaters in my HT1000
only one of the four repeaters will "open" during my transmission. The rest only "open" after I Unkey the PTT.
I confirmed I can hit said repeater with just about every other HT I own from my couch. With no problems.
Any ideas?
RFI-EMI-GUY
Have you tried calling anyone or are you simply "kerchunking"? If you are listening via another radio nearby, you are probably desensing its receiver with your HT1000.
N5XPM
Texas
Any ideas?
What is the FCC callsign and what is the CTCSS and frequencies programmed into the radio?
ElevatorsAndRadios
yarewesog
SoCal
Yup. From my experience, this sounds like the most likely cause. The repeater that does unmute is likely very strong and can overcome the desense. If you're hearing a tail after all of the repeaters, that likely means you're at least getting in. Now whether or not you're getting in well is a different question.
N2TUC
Hello. I heard you on 146.460 this morning. You said you were traveling from Washingtonville to Mt.Peter. Are you using a 10m in you car? or are you able to hit this repeter from up there somehow?
I live in New Windsor, and I'm trying to find a way to stay connected while I travel from NW to Rockland every day.
Thanks in advance.
73
Erica N2TUC
62Truck
Ordinary Subscriber
Ø
Thanks in advance.
73
Erica N2TUC
Just use 146.46 and 147.075 on your commute, those two repeaters should work for you just fine.
N2TUC
I'm on the east side of Orange County. I travel 9w south to the palisades. I won't be able to hit the sams point repeter.
I can pick up the pomona repeter once I get past exit 16 on the palisades. And cell service is terrible, so I can't use echolink on my ride.
62Truck
Ordinary Subscriber
Ø
What is your mobile set up? Those two repeaters should cover your commute with no problem. There are others with the same commute with no issues. The 075 repeater even has a receiver on top of Mount Beacon
N2TUC
I just have a HT for now. I did just add a exterior antenna this weekend, but haven't tried it out yet.
N2TUC
OK, I have those 2a try this morning, I lose signal between the 2 repeters for about 15 min. Do you know if there is one between those 2?
Maybe I need a better external antenna? I'm using a Nagoya NA771
62Truck
Ordinary Subscriber
Ø
Using an HT in the car with just the rubber duckie is not going to give great results. With the external antenna on the outside of the car will work much better.
On the KQ2H system there are no other repeaters heading south between the 146.460 and the 147.075 repeaters.
Those two repeaters cover that commute pretty seamless when using a mobile radio with external antenna.
N2TUC
That 771 antenna is external. I'm thinking I might need a longer one. This one is only about 12in.
62Truck
Ordinary Subscriber
Ø
The antenna you stated you're using is not an external antenna, yes its an upgrade from the stock antenna, but its an HT antenna not a mobile antenna.
You will need an antenna that mounts on the outside of your car for optimal performance.
