HT1250 and wideband
kb1ltr
I purchased one to use for Ham Radio. of course Ham radio is Wide band Does anyone know how to get an Entitlement Key so I can put the radio in Wide band for use with the 2Meter Ham Band?
BC_Scan
Vancouver BC
Id wager a bet its allready in WB mode , however need cable,+ instance of radio software (CPS)
proly best to find someone local to you (ham club) or etc that has old software kicking around on older slower PC as its proly not supported my big M any longer
I'm sure someone can prove me wrong , put originally this would have come via Big M
kb1ltr
when i put the 2Meter Channels in 20 KHz Bandwidth spacing I get an error saying that it needs the Key and when i look in the software it says that the Wide band with capability is not Registered
BC_Scan
Vancouver BC
Big M is your only hope , but again its no longer supported possibly ?
you have to register , take an on line course etc, this is my understanding
kb1ltr
it's not Supported any Longer. they have it for the Mototrubo Software. which will not work for the HT1250. with Software. there is always a way. I am just not good enough with Programming to be able to figure out myself on how to either de compile it to view the Source Code. Or know what Registry File it is to edit it. I hoping someone has done that all ready
nokones
Sun City West, AZ
With my version software, R6.11.10, on my HP Laptop with the XP Operating System, I am able to select any of the three choices of bandwidth without any problem.
n3obl
Ø
PA
Just got w9cr website and download 6.12.05. It’s the last version with wide band available and will read and write no problem.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
You need the second to last release of CPS for the HT series. It will write wideband channels.
Also, you need to use 25kHz not 20kHz. 20kHz is +/- 4Khz deviation.
