Ht1250 cps software question
lightningx54
Berlin, CT
im looking on motorola online under ht1250 under Software/Programming and i only see item number "8264934B01". which says "WARIS VA CPS FIRMWARE" Is this what i need to program my ht1250?
Citywide173
Attleboro, MA
That is the Vehicular Adapter firmware. There should be an option number 2 below it, titled H5177R, which is the HVN9025 programming software that you need. If it isn't there, send Motorola an email, as they may not have given you full access. The CPS is $299.00
Citywide173
Attleboro, MA
thanks for the help. i don't see how its that expensive. it costs more than the radio.
That's the great part about Motorola. The software actually programs the HT750, 1250 and 1550, EX500 & 600 and the CDM mobiles (maybe some more), and is usually sold to shops that charge to program (I've seen from $40 per radio to $1 peer channel quoted on here recently) so you can see where the cost is recovered quickly in most applications. The other fun thing is that the licensing agreement prohibits you from selling (or even giving away) the software once you are done with it, so it's yours for perpetuity.
You will also need a programming cable, which is $63.00 from Motorola, but you can get a decent aftermarket cable on eBay much cheaper. If you need it programmed, send me a PM.
jon47378
ht1250ls software
can someone tell me the exact software i need to program a ht1250 ls, there are so many
bezking
On the Road
The Part number of the software itself is HVN9025. The H5177R package includes HVN9025, the Waris Pro Trunking software, and a RIB-to-Radio cable for the Waris portables (note that this cable alone is NOT enough to program the radio - if you don't have a RIB you need a ribless cable)
Original
... You will also need a programming cable, which is $63.00 from Motorola, but you can get a decent aftermarket cable on eBay much cheaper. If you need it programmed, send me a PM.
I know I'm gonna get flamed for this, but if you are programming more than a few radios, more than a few times, get the original Moto cable. If all you're doing is programming one or two every once in a blue moon, take a chance on a aftermarket.
jon47378
1250 cble
I have two aftermarket cables. one has 3 pins and one has 4, both are supposed to be for the ht1250. The rib cable is what, comport cable? one has comport and the other is direct usb. neither one of them recognizes the radio in the softwre i do have. I will try to find HVN9025 software. thanks
