HT1250 Default Softpot settings
gordonfan954
Southwestern, NM
I was wondering if anybody knew what the default Softpot settings were for a VHF HT1250? Thanks.
Sent from my iPod touch using Tapatalk
KG4INW
Midlothian, VA
Do you mean the ones you set in Global Tuner? There isn't really a default setting as they have to be set with a calibrated service monitor. Or are you talking about mic gain?
jim202
New Orleans region
Each radio will be different. You really need to do a full bench alignment on the radio. Trying to just pick numbers or copy them from another radio will not put your radio on frequency, have the correct deviation and all that.
Don't try to squeeze the last watt out of the transmitter either. All you will do is burn up the PA and then your holding a dead TX in your portable. It also doesn't help trying to get max life out of your battery. Those few extra milliwatts will just add to the shorter life of the battery after a charge.
Jim
