HT1250 DTMF Paging
FirstDue5
Georgia
I got an HT1250, Got all my department channels programmed up, but I can't seem to figure out how to program in DTMF signaling. We use DTMF tones for our department to alert the stations, and I want to set it up to go off when one station gets toned out, I see there is two types of DTMF "signaling" in the CPS, actual DTMF signaling, and then DTMF call. Which one do I use to get a call alert on a channel?
rustyjw
Just confirm that the department uses dtmf tones not the 2 tone system. I thought dtmf were typically used to unlock Knox boxes and set off notification sirens.
Sent from my SM-G920V using Tapatalk
rustyjw
Based on what I have done with 2 tone signaling, call should be silent until alerted the other will should stay open and alert as well.
rustyjw
Those are dtmf tones....what happens in the station when these are transmitted?
FirstDue5
Georgia
Well the station radio (CDM1250's) Picks it up, and it is hooked to a PA system in the station and an alert tone is translated. They have it rigged pretty good to the point I really do not understand. There is an amplifier, and then a switch box where you can switch from "day" or "night" mode. The portables are also Ht1250's and when you turn that on "night" It'll beep and open up like the station radio does. I just need help figuring out how to program that.
rustyjw
I would try to read the portables at the station. That'll tell you how they have it looks programmed.
