HT1250 faceplate
Golay
I got a HT1250 that was used in an industrial setting. The keypad is pretty much wore off, the display has lots of scratching. I have swapped out the front half of a XPR6550 with no problems.
Is swapping out the front of a 1250 any more difficult or tricky that swapping out the front of a 6550?
Didn't really want to take it apart before asking, for no particular reason.
N1GTL
CT
It's like anything else once you've done a few. Quite easy. REX4660B housing kit for the limited keypad and HLN9962A is the HT1250 label that does not come with the kit
Golay
Thank you for the info.
