HT1250 LS+ blinking display
wp4mps
Mayaguez
Hi, I recently bought a Motorola HT1250 LS+ second hand on ebay and when I turn on the radio with a new battery, the only thing the radio does is flash on and off the display light. I see no message from the programming software other than to check the connection and to see if the radio is on. I checked the com port in my PC, I know is the right one. Could I have a bad EEPROM in my radio. Is there any hope for it?
gary123
It sounds like a bad program to the radio. I would see if you can get a good image and program it to the radio. Also sometimes going into the service menu will fix some codeplug issues.
wp4mps
Mayaguez
Ok, I forgot to mention that once I lock the battery on and turn the radio on, it's display and small light on top start blinking, but to turn the radio off, I have to detach the battery.
I've been told today that the radio was "stunned"?.
jcattey
I am having the same problem with my HT1250 with the screen and scan light blinking and the only way to get it to stop is to pull the battery. Any Ideas??
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Yup, sounds like it has been remotely disabled. Some manufacturers call it "stun/kill". Motorola calls it selective radio inhibit - allows system owner to disable stolen or missing radios.
jcattey
great...I picked this radio up on ebay, sounds like im SOL then...thank you for the heads up
MPFD535
NJ
I might be wrong but I dont think you can stun a ht1250, you could if it had a option board, like passport, in it. but normally it says disabled. Have you tried to program it? If it had a eprom fault the new cps fixes it. I would read it and change the code plug and load it back in.
jcattey
So i turned it on and it came up EEPRM CS ERROR, I was unable use CPS R06.11.10 to reset the codeplug and ended up useing a code plug tool to flash a the same tamapa into the radio and it went back to blinking.....im at a loss. Now when i try to read the radio or resend the tamapa it says the radio is not responding. Im thinking this radio is gonna have to have a depot trip.
jcattey
The radio is not responding to the codeplug tool or the firmware tool. Just the blinking display, buttons and scan light. Only way it will stop is if the battery is pulled..... any other thoughts before I take this radio out back and shoot it?
