HT1250 MDC ID not showing up when transmitting.
Mboy00
Aberdeen Township
Tried all I could with the ID's of the radio showing up with MDC and PTT on a analog channel, still doesn't work. Any ideas?
n3obl
ØAES-1024
PA
Are you using another radio with the same id? The radio will be confused if you use the same id. also check your RX system.
a417
Repeater Access ID Opens when I put the option for TX as well, should I put that as the radio ID?
Do you need Repeater Access ID capability?
repeater access != ptt ID, at least not when used correctly.
tropiradio
I think the OP means that he cannot make the ID show up on the radio display when another radio with MDC keys up. Make sure that the proper MDC signaling system is selected for both Rx and Tx on the desired personality, and the selected system parameters are set correctly. If you also want a label to be displayed instead of the code itself, just create a corresponding MDC call.
