HT1250 HT1250 MDC1200 ID Delay
saksorn013
Thailand
I have a Motorola HT1250. I use it with MDC1200, which is another radio I use. I set it for Pre Only.
When I release PTT, the screen of HT1250 keeps showing ID for about 10 seconds, how can I fix it?
Thank.
K2NEC
5F6
You cant. If you dont want to see the ID, press the back button. Otherwise disable ID display.
saksorn013
Thailand
Because in other models that I have It goes away immediately when I release PTT, I don't want to not see it. But I want it to disappear immediately when the PTT is released, it can't be done?
saksorn013
Thailand
I used it with the MDC1200 system together, even though it did not go through the system. But it can still use identification (Call Alias) and Call Aleart. I am not using it to annoy others.
"I am asking how the ID is showing after I release PTT, which in other models I have xpr7550e, xts2500i it is not."
K2NEC
5F6
It's a different model. Can't expect them to behave similarly.
