HT1250 not transmitting on repeater
Clay, AL
Nothing has changed in programming that I know of and I am unable to transmit on repeaters on several channels. Its like it just stopped working. It does transmit just fine on channels that do not use a repeater. Any ideas?
kma371
Is your ABC toggle different than what it normally is? That sometimes switches from talk around to repeater mode. Try that.
Devilz311
NJ
I think you mixed up portables, there's no ABC switch on the 1250.
OP:
It is still possible it's in talkaround. On the channels you are experiencing problems with, is the talkaround icon in the display? It is the one right about the LCD clock.
It may be an option in the menu, or it may have been assigned to one of the programmable buttons.
Clay, AL
It is not in talk around when im attempting to hit the repeater. I have programmed one of the side buttons to flip to talk around and the symbol shows up and it transmits just fine, flip back to the repeater and nothing.
jim202
New Orleans region
Put it on a service monitor and see if it is sending the PL. Most repeaters require a CTCSS tone to trip the repeater. No tone being sent, no repeater being accessed.
KG4INW
Midlothian, VA
How far away from the other units are you when in talkaround? If you're real close, then maybe the PA is on its way out so it still TX but not far (i.e. not enough to hit the repeater). If you're still talking over a long distance, then I don't know. Any MSS will have a service monitor so it may have to go to them.
Clay, AL
At the longest on talk around would be about 100ft. I will try contacting dispatch on talk around and see if they can hear me on my next shift.
mm
oregon
Ask them if they changed to narrowband also, if your radio was not previously set to NarrowBand and the repeater now is, then this could cause a problem.
kma371
If this is a "work" radio, why don't you let your radio tech know there is a problem and let them fix it? There may be contract issue if you attempt to fix it yourself.
cifd64
Northern Passaic County, NJ
And if it isnt a work radio, follow these steps for programming a radio to work on a system:
1) Make sure your TX/RX freq's are correct (they are not the same on most repeaters)
2) Make sure the proper spacing is selected (25/12.5khz)
3) Is the repeater using DCS/PL? They have to be the same in the radio (TX and RX might have different connect tones.)
4) Are you allowed to have a radio on this system? IE, is this a personal radio? If it is, you should get permission to operate on it.
Clay, AL
Its a personal radio used with my Fire Dept. All info in those steps are correct. I will talk with my chief to see if he can get it fixed. We are getting ready to switch to digital not too long from now so not sure if its worth fixing. If I send it to a dealer how much do you think it would cost?
cifd64
Unless you know the dealer personally, he/she may not program it to TX unless your chief OK's it (that has been my experience).
As far as worth fixing, thats your call. If the entire area is going P25, then no.
South Central Minnesota
If it is truely broken and needs repair...If you send it to a Motorola shop, the cost will be more than the radio is worth. I had an estimate of like $600 to repair a $5 part on a HT1250.
KG4INW
Midlothian, VA
Possible, but it's hard to tell without actually seeing the radio in person or on a service monitor.
radionerd13669
Useless Contributor
Northern,New York
What were your results when you tried talking on simplex. Do you use this radio on any other channels other than the repeaters? What are your results with that
In one of your post above you said that you programmed the radio? If that's the case even though you say its 100% percent correct I would double check most of the times these issues are from not programming the radio properly
If it does truly have an issue I would say no it isn't worth repairing most time the cost could by you a new radio
2009KVFD976
Im having issues with mine not sending out MDC1200 on any of the 5 fireground channels i have. They are all simplex with same PL tones on both TX/RX freqs. Also there are 4 state channels with same TX/RX and no PL with same result. But i have a simplex channel, same TX/RX freq with NO PL and it sends the MDC.. Is there anything i can do to correct this?? Ive tried switching T/A on and off but nothing...
