HT1250 Problem?
FirstDue5
Georgia
I am programming a VHF HT1250 to listen to a local Fire Department, I get everything squared away and program, but when I am listening in on audio, every transmission sounds garbled and has alot of static, is there anything I am doing wrong? The dispatch frequency is just a normal Vhf frequency.
clbsquared
Isle of Wight County
Make sure you have it set to narrow band. 12.5 spacing, not 25. Double check your frequencies and PL/DPL tones. Do you have the correct antenna? It could be a number if things. Your radio could possibly need to be aligned.
Sent from my HTC One A9 using Tapatalk
RFI-EMI-GUY
Normally, if a radio is listening in wideband mode to a narrow band TX, there will be reduced audio level, not distortion. Now if their TX is wideband and the radio set to narrow band, there will indeed be noise and distortion.
1 make sure your local FD has completed narrow banding. If their licence reflects a waiver, they may still be in wideband, or no waiver and they are in violation of FCC NB mandate.
2 make sure your radio is programmed for the appropriate bandwidth. If narrow band, try turning compandoring feature off. Or on if they use compandoring.
3 make sure your radio is operating on frequency. It is surprising how far they might drift in a couple years.
Sent from my SM-T350 using Tapatalk
RFI-EMI-GUY
If I need to have it aligned, how do I got about that?
Normally, the frequency might drift. Check using a frequency counter in the TX mode. You need the CPS tuner software to adjust it.
12dbsinad
Static as in low signal strength? If so it could be:
- Radio has a RX issue as stated before, off frequency, wrong antenna on radio, etc.
- Are you in the coverage area when trying to listen to the FD?
FirstDue5
Georgia
It's not like it's a low signal, I'm in the county. It's just garbled. It helped a little to turn companding off. It has the NAD6502 Vhf antenna on it.
clbsquared
Does it have this issue no matter where the radio is? If you're outside in an open area with no visible obstructions, does it still have static and sound garbled? VHF handhelds have a lot of RX and TX issues inside structures and in moving vehicles.
IAmSixNine
Dallas, TX
Are you sure its garbled? maybe muffled would be a better use? i usually dont associate analog with garbled.
MTS2000des
5B2_BEE00 Czar
Sounds like it either needs an alignment, or it could have a bad front end filter.
Either way, it needs to be put on the bench and checked out with proper test equipment.
The Cherokee VHF system is pretty robust and you should be getting stellar receive with a decent portable, unless you are deep inside someplace like the outlet mall or in the low spots around Waleska.
12dbsinad
If they aren't using companding then it should be off or it will not sound good... Have you looked at the RX audio settings? Is it Disabled, Compressed, Low-Level, etc?
It could be something like a bad speaker... do you have a RSM to plug in and try?
RFI-EMI-GUY
Also try moving the radio to a different location to rule out local interference, like from a PC or plasma TV. Still my money is on the reference oscillator off frequency.
