HT1250 Programming Issue
cjp6691
Donora
HT1250 Programming Issue - UPDATED!!!!
I have a BRAND New HT1250 VHF and the Verison 6 CPS and when I go to read the codeplug from the radio, it will not open the codeplug. It gives me a message stating that there is a MDC Group Block and it doesn't open the codeplug. I will post the exact message when I get home from work, but if anyone has any suggestions, I'd appreciate it.
Thanks,
Casey
cjp6691@comcast.net
ob123
NJ
During the last update, the codeplug may have been interupted enough during the programming mode and corupted the MDC call.
bfd242
Louisiana
If you have an old codeplug saved you can try writing it to the radio then try to read it.
SLWilson
Ohio
If.....
If someone shut the computer down or the battery in the rib box went dead during the writing process TO the radio, you'r done.
It has to go back to the factory for repairs.
Same way with the CDM mobiles.
Our radio shop guys apparently had a new tech learning the Moto programming. He screwed up BIG TIME!!!
When the PC is writing to the radio, there is a beep tone toward the end of the writing.
HOWEVER, that does NOT mean that it is DONE writing. IF for some reason you STOP, UNPLUG, UNHOOK or otherwise bother the programming cable BEFORE you get the SECOND beep which is a two-tone beep, it is toast!!!! The radio HAS to go back for factory repairs....
Steve/KB8FAR :(
cjp6691
Donora
Thanks for all of the suggestions, but now i am sort of thinking that it is not a software issue. What I think it is, is that the radio has ALOT of MDC1200 ID numbers programmed into it (222 of them). I think it is having trouble reading all of them at once (I could be wrong) but that's what it seems like. I don't want to overwrite the codeplug YET, until I get all of the ID numbers for my county Units, once I get the ID numbers for the aliases, I'll overwrite the codeplug to see if that works.
Thanks again for the information.
