ht1250 programming
flyboy4545
I purchased a ht 1250 on ebay and I am having trouble. I am using the newest software and it shows an error of " out of region". Model is aah25rdh9aa6anfd. Any ideas?
joespca
Amherst NY
That means the software you have will not work on that radio. You need to HEX edit the CPS to allow that region radio to work with current CPS
flyboy4545
How do I do that. Also I was told that the "fd" at the end of the model refers to federal. Which means I need government software.
n3obl
ØAES-1024
PA
Negative dont need a hex edit. Simple registry change
This hack will allow any version 6.0 or above Pro Series CPS program all available regions, not just the region installed. I tried this with R06.05AA on a fresh machine and was able to confirm AA, LA and AZ.
Obviously, one should only try this if you are comfortable with editing your registry... Please make sure to make a backup of the key before you make any changes.
Set the value of the following key to "@%&MAHUS" (without the quotes) and restart your CPS.
HKEY_LOCAL_MACHINE\SOFTWARE\Motorola\ProRadio\FSK\SerializedString
clbsquared
Isle of Wight County
If you’re still unsure about how to do the hack described above, just google “Motorola HT1250 region hack”.
There’s some good info and even a video to assist you.
flyboy4545
Also I just received a xts5000 uhf with FPP. But When I input data via the panel it asks for a password. I then pick ok and keep going. Seems to work as it transmits. What is this for?
KG4INW
Midlothian, VA
A password can be set to block unauthorized programming but isn't needed. Even if not set, it'll still ask for it but pressing OK lets you proceed. It's hardcoded so no way to prevent the prompt from showing.
chrismol1
What exactly was the reasons for the FD at the end of model number? I've seen that before on the waris series. Only thing ive seen to remember was something federal? I don't get why
flyboy4545
Motorola told me it was to be more secure for the government. This radio came from Europe on ebay. I had no idea that fd radio were made.
Echo4Thirty
Colorado Springs, CO
There is functionally no difference between the FD and NA radios other than perhaps a much higher price and needing fed CPS (or the above mentioned registry edit)
