ht1250 question
nick223
Ottawa Illinois
i have an ht1250 that had error code EEPROM HW ERROR i sent the radio in and is now fixed and radio is programmed.
It seems like the radio isn't recieving properly Some channels i get just the base radios others i get just the vehicle traffic but not the dispatcher traffic where i had in the past. Programming is all right i wasnt sure it something could of happened with that error code? The radio does have a shorty anntena.
Wasnt sure it there is something i could check or do?
Thanks for your input
Nick
RKG
Boston, MA
The error message meant that the radio was detecting a checksum error on the codeplug, which was corrupted when you sent the radio to Depot.
Suggest you re-write your archive of the correct codeplug back into the radio.
nick223
Ottawa Illinois
I don't think I have the original code plug of this radio it's been oos for over a year just got around to sending it in.
RKG
Boston, MA
Unlike some other products, the HT1250/CDM CPS does not mask for radio serial number on a write. So if you have an archive file for another HT1250 that has exactly the same model number and feature set, you should be able to write that to your radio. If it works, then read the radio, archive the read, and start editing.
