HT1250 Questions
12dbsinad
I am having a brain cramp. That, and I really don't program many HT1250's.
My questions are,
1- Is there a way to enable the Priority "beep" when traffic is heard on priority channel during scan?
2- Radio does not seem to be muting, or at least partially muting, the MDC-1200 data burst. I don't see a setting for this.
3- Can you set the Priority #1 to "follow the channel selector"?
Thanks for any and all help!
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
My questions are,
1. On the General tab of the Scan List, check the Priority box. Then on the Radio Configuration section --> Scan tab: Priority Alerts check the Priority Scan box.
2. Signalling ---> MDC System ---> MDC System - 1 ---> DOS tab adjust the Auto Mute time. Before you do this, make a note of the original setting so that you can change it back if you encounter other problems. Mine is currently set at 500 ms.
3: In the scan list, use the drop downs and place <selected> in position #1. That should be standard practice for most any scan list in a two way.
Thunderknight
Bletchley Park
Steve beat me to it, but I just checked CPS.
In addition to Steve's step, I think you also need to check the box that says "Priority 1 (First Scan List Member)"
1 in your cps in the radio configuration under scan, select scan alerts priority scan, check this box. I don't recall but I thought that is what that did.
2 you may need to adjust the mdc settings. Ensure "and or" is selected for the muting type on all systems required. Try 1200 and 1800hz, if that doesn't help try 1200 or 1800hz. Adjust your dos auto mute duration to 500 and dos coast to 50 those are default settings. If not try 250 and 50. Default petite under advanced is 500 ms and pre time is 0. Depending on how the system is you may need to adjust as needed. Also ensure display I'd decode is enabled if you desire the I'd shown on display.
Also try pl scan for priority and non priority, or priority under advanced in the scan list tab under signalling.
3 your asking if channel one can be priority over everything? So if one moves the selector will channel 1 be priority always if traffic is present? Yes, in each scan list for each zone/scan list per say select priority 1 in the general tab and under the list tab in scan make the slot 1 the desired priority. If you wish to have it where the channel selector is what determines priority in slot 1 make sure selected is used then number your channels in order. Be sure if transmitting under the tx configuration tab you set the desired tx channel. It can be selected ie the channel the knob is on or a pre selected conventional personality.
It's been short while but I believe that's what your after. I'm away from any machine but if I recall those are whst your looking for. Hope that helps.
12dbsinad
Got it. Thanks, Steve.
