HT1250 scan lists
firefive76
Kansas
I see in the CPS that you can create more than one scan list. How do you "switch" to another scan list?
CommJunkie
FN20jf
You should have different channels in different scan lists. Just go to a channel in a certain scan list, and turn scan on. It will only scan the list in which the channel you are selected is a part of.
RKG
Boston, MA
Each "conventional personality" has a scan list defined as one of the "personality's" parameters. This is the scan list that will be employed whenever the personality is selected and scan is invoked.
As a practical matter, you program the radio as follows:
Create your conventional personalities. A conventional personality is a set of channel parameters that are available for assignment to zone/channel slots.
Assign your personalities to zone channel slots.
Define your scan lists. Each scan list contains members (defined in terms of zone/slot, not personality number), and data on priority (if used).
Now, go back to your personalities and assign the appropriate scan list to each one.
It may sound convoluted, but the system actually works quite well and it makes subsequent channel plan maintenance a breeze.
firefive76
Kansas
Great! Thanks for both of your replies, I understand the scan list option in the personalities now. Sure not like the Kenwoods and Maxons that I have programmed before.
