HT1250 Talk Permit Tone
Skypilot007
Medford, NJ
You could enable a pre DTMF tone if the 1250 has that option. Set the burst speed to the max, set a 3 digit number and it kind of sounds like a trunking radio talk permit tone. Only draw back is this DTMF burst goes out over the air.
medic611
NC Foothills
For the super squirrels to perform out there !!!!
RodStrong
West
It lets you know you have keyed up which is very important so you don't have an open mic.
If you haven't done so already, you might consider checking/setting the time out timer while you're at it. It certainly would help with open mics. Good luck.
N0BDW
Livingston Co., NY
We used a pre-only PTT ID via MDC signaling w/ long sidetone for this. Unfortunately we found it did not work well for radios used with mobile repeaters (especially if the repeaters also had signaling enabled) and so we had to disable it on some radios.
