Ht1250
specialmed1
California
Ht1250 password problem
We just received a new HT1250LS+ and tried to read it and its asking for a password. The person we purchased it from does not know the password. How do I get the password or reset it to be able to read and reprogram
specialmed1
California
i have been trying to find that out, no one knows anything about the radio except they had the radio and battery and turns on. So looks like this radio is not going to do me any good
specialmed1
California
we have tried to read the radio and its asking for the password. I have tried to copy from 1 radio to the other ( same firmware and code-plug )and no luck there either. And sending to the depot is 250 plus shipping
DPapay
Morris County, N.J.
From limited experience with this, if the radio has an older version codeplug in it, meaning it was last programmed with an older version of CPS, then you used to be able to just write over the existing password protected codeplug, with one that was not protected. You still could not read the radio no matter what. Then the software engineers discovered this, and quickly stopped it with the next version. I do not know the cut-over version, but I was using 4.00.00 a long time ago and it worked. Naturally if the radio has been touched by the newer versions, you are out of luck.
