HT750 16-ch...OEM Frequencies?
HoboCoastie
Gallatin, TN
Hello all. Been lurking in here for a couple years now.
I've got some old HT750's that I'm looking to DRMO,
They did have only 7 channels that we utilized on the ship (Coast Guard) and I'd like to make sure all 16 channels work, however it's been very difficult finding the original 16 frequencies.
Everything works as far as programming, no connection issues, reads/writes, etc.
I looked in the database here for the Motorola default frequencies and just plugged 1-16 from the RDX defaults into my codeplug and sent it. 1-10 work just fine and when I read the radio, 1-16 show up, but 11-16 tone out on the radio which usually indicates that channel is not in use?
Obviously, this is only a collateral duty for me and I'm NO expert. What am I doing wrong? Anybody got the frequencies I need?
Thanks for any help forthcoming!
Hobo
KG4INW
Midlothian, VA
You need to go to the bottom of the CPS "tree", expand the Personality Assignment to Zone, go to the channels tab, right-click on the left side then click on "add at end" enough times to enable the other channels. Then, click the drop-down menu on each new channel to pick the personality you want to assign to that spot.
In Professional CPS, personalities don't equal channels until you assign them as such.
NMO's installed, while-u-wait.
These commercial radios don't come with "default" channels like the consumer grade or low end commercial grade do. They come from the factory blank and it's up to the radio shop to program to the specific needs of the user.
Finding 16 "itinerant" type frequencies, or like you did, the preset channels from a lower tier radio will do just as good.
Likely these had the 457MHz marine UHF channels in them from USCG use. I was on a 180' WLB, so we didn't need radios, just used the 1MC or yelled.
HoboCoastie
Gallatin, TN
Yep, that's about where these were at. I'm on a 225 WLB! Good to see another Black Hull Sailor!
HoboCoastie
Gallatin, TN
That did it! All 16 channels working like a champ now. Thank you much Sir!
Hey! Those 225's are some good looking ships. I was on the Ironwood (WLB-297) out of Kodiak back in the early 90's. SN/deck force. Loved it, great duty, learned a lot, good times. It was my only underway duty, but I'm really glad I got to spend it on a black hull.
