ht750 no rx
WQAJ741
My ht750 won't rx unless I hold the monitor button...I checked the programming, everything looks ok as far as I know except that I can't hear anything without monitor being pressed...
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
If you have TPL or DPL set on the RX frequency, go to the Options tab for that personality and make sure the Unmute/Mute Rule is set to STD Muting, STD Unmuting.
WQAJ741
Thanks, I checked that and don't seem to have any luck....
WQAJ741
Tried that already, I'm hoping it's not something in the radio thats going to cost a lot...Even with CSQ I still couldn't hear anything without pressing the monitor button. I do have MDC enabled on some channels, but not QuickCall. Does that make a difference? I wouldn't imagine so..
WQAJ741
When I disable MDC feature on the channels it receives just fine, but if I enable MDC, it doesn't....it just started happening recently and I'm not sure why. Even if I just have the MDC set to mute the data burst it still wont Rx.....
BigLebowski
Piedmont NC
Sounds to me like MDC is set to "AND" instead of the proper "OR" signalling type.
WQAJ741
That might have been it, in all honesty I just messed around with some settings and got it to work. thanks!
