HT750 programming?
tiawah466
CLAREMORE,OK
In CPS goto signaling, then goto the type of signaling system that you are using and turn on the PTT ID feature, in here you will be able to set you radio id number and where you want the tone(start or end of transmission). Then you would have to program the other radios that are on your system with your radio PTT ID number.
