HT750 UHF questions
UnidenBulldog
Are there any antennas that would allow me to extend the range of the ht750 UHF to about 10 miles? Thanks
bezking
On the Road
The only antenna-related thing to do to help with range would be to make sure you're using the whip antenna instead of a stubby antenna.
davidgcet
sure, but it would no longer be very portable. you could install a base antenna at each location and have no issue with 10 miles. otherwise, you need near perfect conditions for a UHF 4W portable to talk that far to another portable/mobile without a repeater.
Homebrew
Make one:
Get the BNC adapter for the radio, then put a BNC connector on the end of about 15" of coax, and make a 12" sleeve dipole. Cover the whole thing with heat shrink. If you don't know what a sleeve dipole is, Google is your friend.
Raptor05121
Live Oak, FL
exactly. power is the limiting factor here, not the antenna.
