Hudson County Sheriff's
NJEMT12982
NJ
I have all their channels programmed into my scanner, however, I can only hear the dispatch end of their transmissions. Almost like Kearny. Am I missing something?
NJEMT12982
NJ
What can I do to correct this receiving issue? I use both FreeScan and Arc-XT software.
Northwest Bergen County, NJ
Isn't there a column on the FreeScan programming spreadsheet that allows you to designate that you want to receive analog AND digital signals on the selected frequency? You won't be able to select a CTCSS code or a NAC code if you use this option, but unless there's co channel interference, it should not matter.
62Truck
Ordinary Subscriber
Uranus
If there happens to be co channel interference and a PL and NAC are needed. Could always program one channel as analog and one as digital.
