tcg
Hi,
I just installed an ST2 (scantenna) outdoors. It is on a mast 28' off the ground. The mast is grounded with #6 bare solid copper to an 8' copper ground rod. The bottom of the mast is 12' off the ground. It's mounted on a second story deck.
The RG6 coax runs 16' down the mast and is connected to a coax ground block right before it enters the house. That ground is a #8 insulated stranded copper wire. it follows the mast ground and attaches to the same ground rod.
Another 16' RG6 coax cable goes to the scanner, an old RS PRO-2030.
I run an audio cable from the scanner to my computer the hum is introduced at the computer.
If I disconnect the coax ground the hum stops.
Any thoughts?
Matt
Any thoughts?
Matt
