Humboldt,Saskatchewan EMS Frequencies.
walleye
Saskatchewan
Does anyone know what frequency the Humboldt EMS would use :?:Thank-You guys for all of the wonderful information!
richster
Regina, Sask.
Hi Walleye,
More than likely they are on Sasktel Fleetnet. I am not sure what talkgroup they use though, because they do not use system 1. The old VHF frequecny EMS used was 158.760 Mhz. Who knows they may still use it because your local hospital had a licence for it. But it's probably only used for backup.
Here try these. They are from my old Saskatchewn frequency book.
...RX...........TX.......................LICENCEE...................................
0.2770....................HUMBOLDT SK (AIRPORT BEACON)
123.2000 123.2000 HUMBOLDT AIRPORT, SK. TOWN OF HUMBOLDT
140.5500................HUMBOLDT SASK. ROY B MCNALLY
149.1250 149.1250 HUMBOLDT SK DOUGLAS A THOMS
149.8300 149.8300 HUMBOLDT SK SW10-39-22 W2 BRUCE PUETZ
150.7850 150.7850 HUMBOLDT SK. NORLIN CONSTRUCTIO
150.8300 150.8300 HUMBOLDT SASK LAWRENCE M BERSCHE
151.8800 151.8800 HUMBOLDT SK. NORLIN CONSTRUCTIO
154.5250 154.5250 HUMBOLDT MICHAEL LAWRENCE B
156.8550 156.8550 HUMBOLDT SASKATCHEWAN R M OF HUMBOLDT
156.9150 156.9150 HUMBOLDT SASKATCHEWAN R M OF HUMBOLDT
158.5500................HUMBOLDT SASK ST ELIZABETHS HOSP
158.7600 158.7600 HUMBOLDT SASK ST ELIZABETHS HOSP
159.5550 159.5550 HUMBOLDT, SK (NE 8-36-23 W2ND)
160.6650 160.6650 HUMBOLDT SASK RAC/ACFC - CNR
160.7850 160.7850 HUMBOLDT SASK RAC/ACFC - CNR
160.9050 160.2150 HUMBOLDT SASKTEL RADIO SITE RAC/ACFC - CNR
160.9350 160.9350 HUMBOLDT SASK RAC/ACFC - CNR
161.4150 161.4150 HUMBOLDT SASK RAC/ACFC - CNR
162.2850 162.2850 HUMBOLDT SK 1108-21 STREET WALTER J SILZER
163.2450 163.2450 HUMBOLDT, SK (NE 23-36-24 W2ND) CARL LUEKE
163.9350 163.9350 HUMBOLDT SASK RODGER CARL ECKL
164.1150 164.1150 HUMBOLDT BRIANS ELECTRONICS
164.1150 164.1150 HUMBOLDT SK BRIANS ELECTRONICS
164.1750 164.1750 HUMBOLDT SASK 206-2 AVE WAYNE H KALTHOFF
165.1350 165.1350 HUMBOLDT HAROLD R FRASER
166.1250 166.1250 HUMBOLDT, SASK. LINS FARMS INC.
166.1250 166.1250 HUMBOLDT SASK MURRAY T LINS
166.3200 166.3200 HUMBOLDT MONTY KOVLASKE
166.3800 166.3800 HUMBOLDT GORDON REINEKE
166.6050 166.6050 HUMBOLDT SASK OLLERICH FARMS LTD
167.6250 167.6250 HUMBOLDT SASK BROCKMAN ENTERPRIS
168.1050 168.1050 HUMBOLDT SK CLARENCE BAUML
169.1700 169.1700 HUMBOLDT TOWN OF HUMBOLDT
169.1700 169.1700 HUMBOLDT SASK TOWN OF HUMBOLDT
170.4450 170.4450 HUMBOLDT SASK FRED GRIEMAN
171.0150 171.0150 HUMBOLDT SASK WOLVERINE FARMS LT
171.3300 171.3300 HUMBOLDT WERNER YUNGMANN
171.7950 171.7950 HUMBOLDT SASK HUMBOLDT AUTO BODY
171.9300 171.9300 HUMBOLDT SK BIG SKY FARMS INC
172.1550 172.1550 HUMBOLDT HAROLD RUDOLPH HER
172.3050 172.3050 HUMBOLDT SASK GORDON LEMMERICH
173.3850 173.3850 HUMBOLDT GORDON MUELLER
453.8875 453.8875 HUMBOLDT SK JEROME WINKEL
460.6625 460.6625 HUMBOLDT SASK ST ELIZABETHS HOSP
460.7125 460.7125 HUMBOLDT SASK ST ELIZABETHS HOSP
460.7625 460.7625 HUMBOLDT SASK ST ELIZABETHS HOSP
464.1500 464.1500 HUMBOLDT SASK GARY LUEKE
464.1500 464.1500 HUMBOLDT SASK MYRON LUEKE
464.7500 464.7500 HUMBOLDT AGRICORE UNITED
469.2625 469.2625 HUMBOLDT SK CHARLES KIEFER
emsguy
As far as I know, all EMS in Sask. is on the Sasktel Fleetnet system. According to the Saskatchewan Scanner web page, Humbolt is on system 5, and the talkgroup is 12-087. The fire dept. should also be on a common dispatch talkgroup for the area. Fire and EMS may still use Vhf for on scene use.
RBerezowski
Regina, Saskatchewan
Although every Sask. EMS agency seems to be on Fleetnet, there are not a lot of Fire departments on there. Only Swift Current and Prince Albert as far as I know, and a few of the smaller departments.
You'll find a lot of the rural fire departments on 156.885 or 156.855. Those are common frequrencies for rural Sask. Fire departments. 156.915 is a province wide EMO channel. All of the rural fire departments have it in their radios, but it is seldom used, only for really large scale emergencies.
As for Humboldt, well the licence list above shows the RM of Humboldt on 156.855. That will be the RM Fire department, but I'm not sure if that covers Humboldt proper, or just the surrounding rural area.
Rob
emsguy
Most rural fire depts. were required to get some type of fleetnet radios when the province went 911. Our fire dept. has two portables that we use to communicate with our dispatch. We still use 156.855 for truck to truck and on scene comms. The province is divided up into fire disticts:Alpha, Bravo, Charlie, Delta, Echo and Foxtrot.
Each distict is broken down into 4 talkgroups. The talkgroups for Echo are: Echo main:14-125, Echo-1: 14-126, Echo-2: 14-127, Echo-3: 14-130.
RBerezowski
Thanks for the info. I don't hear too many rural fire departments, but that's likely due to my location.
So where abouts is Echo district? I assume the districts match the areas covered by each 911 answering point / dispatch centre?
Rob
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
I know this doesn't necessarily apply to SK province-wide, but I figured since SK and AB are neighbors it may be more prevalent than not. 158.76 is a province-wide common ambulance channel in Alberta, most often used for communicating with another EMS agency. Example - BCAS and other services transporting by ground into Calgary often call on Provincial Ambulance when they run into trouble en route and need a meet with an ALS truck out of Calgary.
RBerezowski
Actually, EMS was using 158.760 here in SK for a province wide common channel, before they all went to Fleetnet. I haven't heard the frequency used for quite some time. However, I do believe some of the ambulances may still have the 158.760 transceivers in their units. At least, I do see the long whip antenna on some of the ambulances. Not many though.
I still keep 158.760 plugged into my scanner.
Rob
emsguy
Echo district is roughly north and east of Regina. It takes in Lumsden, Southey, Strasbourg, Lestock, Fort Qu'Appelle, and anything inside of that. Dispatch is primarily handled out of Regina EMS but each Dept. can contract the services of any other dispatch service in the province (ie. Yorkton, Saskatoon, PA or Regina)
