Huntsville pd
pony
NW, Alabama
I went to Huntsville last weekend and I wanted to tryout the trunking function on my br330t, I loaded the Huntsville pd info from here loaded it with uniden usad software and went on my trip. The scanner was totally silent while I was there. Up here in Franklin county we don't have any trunking so I may have did something wrong. I should be able to here this on my radio right. Motorola Type II Smartnet analog. One more question there was 4 frequencies in colored red and the rest were black, I just put the 4 red ones in my scanner, Should I have entered them all?
pilotman1260
Yes you have to put all the channels in scanner,there are some control channels,but you need all 20 channels in to hear anything,some of the channels are data channels so a little annoying,when all you hear are beeps and hissssssss!You do need to put all them in.
Caddop22
Huntsville, Al.
Make sure you input 851.2625, it is being used as a CC quite often. HPD has re-banded so look at the new CC's posted in the DB also.
JoeyC
Senior Member
San Diego, CA
If you selected CONTROL CHANNEL PROGRAMMING when you programmed the system, then NO, you do not need to enter all of them.
